TheOldMaster
I just got the game running thanks to klov.
I made the video to ssio error when plugging in monitor plug. GENERATES WHITE SCREEN. OOPS.
TO ALL FIXING THESE GAMES:
MAKE SURE YOU PLUG VIDEO CABLE INTO MIDDLE PCB NOT THE SSIO.
THE PINS ARE HARD TO SEE AT FIRST. Missed them completely at first glance/ check.
The tip off was the connector is one pin too small but lines up with key.
Also a search for white screen tron mentioned this easy mistake.
Earlier i posted about the arcade shop switcher.
Luckily i still had +12v. Ac coming from the mcr brick assembly, so i proceeded with the install.
I powered up the game and it coins up plays etc.
But has a bright white screen only. DAMN!
Switcher is at 5.07 under load at terminals, 5.12 freestanding before hookup , and 5.07
at board connector.
All seems well no hum etc.
There is a yellow led on the super sound board.
The yellow led is not lit. Should it be?
I noticed the connector on the video output from the board is short one pin in size, but the
key lines up correctly with space between the pins.
Im close , when i hear the start up music makes it all worth while.
at board connector.
