Discs of Tron Brick repair
viperpack
Toronto, Ontario
Hey Guys, i noticed on the power brick of my Disc of Tron, one of the black white cable is ripped? Can it still be workable with one of them cut? I see each wire contains two same color wires.
I don't see any "ripped" wires. If the frayed insulation on that one wire is concerning for you then remove the cover and see how it looks underneath. If there is any exposed bare wire, cover it how ever you can ... shrink wrap, electrical tape, whatever.
The manual shows Blk/Wht as the center tap/ common ground, so you will be fine as long as the other blk/wht and red/wht are not damaged.
