gamingsince80s
I played it last night for a while. It kept shutting off shortly after I turned it on. It probably turned off and on about seven times the first half hour I had it on and then it only did it one more time in about an hour. When it shut off it would come back on within about five seconds.
I was thinking about checking all the connections at the power source. Since this is my first pin I don't want to go sticking my hands in there without knowing what I am doing. Is it pretty much safe, for me and the machine, to check the connections if I just unplug it or is there anything in there that holds power that needs to be discharged?
I'm thinking something may have come loose when we transported it because when we turned it on at the seller's house it didn't do this and did as soon as we setup it up here. What do you guys think about checking the connections at the power source or is there anywhere else that I should look at?
