Diodes added on underside of WG6100 deflection pcb
87 t-66
North Carolina
I am refreshing this 6100 deflection PCB and am curious as to why these diodes were placed on the bottom. It appears someone has previously worked on this board which often worries me. Any ideas? Should I leave them?
BTW, your deflection board also has the two 1N754A zener mods added. So it is consistent with the upgrade instructions. See Figure 7 in the TM-268.
thanks. i will plan on leaving them as-is. do you know what the purpose of the upgrade is? the monitor came from a space duel which shows no sign of being converted to MH.
It has been a long time, you cannot really assume the history of the cabinet, nor the monitor, nor the individual boards in either. Also, the owner(s) might have decided to do the protection upgrades even if not being used with a MH boardset.
The back-to-back zeners are to clamp the X and Y inputs to the deflection board. This protects both positive and negative transitions. Also protects the input board (i.e. logic board) from any reverse transients.
The 1N4002 are attached at P600/700 and are thus back-biased across the main deflection X/Y transistors. Due to the coil inductances, these "body diodes" for the BJT switches likely help in reducing inductive kick that might, over time, fail the transistors.
Agree with your thoughts, VectorCollector.
One thing I've not heard over the years is whether the later P327 and P339 deflection boards would benefit from these modifications. My assumption is yes as there is little difference in this part of the deflection board between the various revisions. Obviously, I appreciate hearing a more detailed and technical response from those more versed in these boards than me.
Scott C.
Scott C.
You're correct Scott
The later models don't need the clamping diodes, but they would benefit from the 1N400x fitted across the bottlecap transistors
I looked into this when making the repro deflection bd (A P327 revision)
The condensed version of the inbuilt IP circuit makes adding the clamping (back to back diodes) not possible I seem to recall
Great explanation, dezbaz. Thanks.
Scott C.
Good info.
I just started on 4x 6100 chassis this weekend. 2 of them are vanilla p314, one has the input protection pcb, and the last is the P327(?) and the later model HV board. Planning on getting them all upgraded and going at the same time. Been reviewing a few posts.
