Dino world egg dispenser
howie2673
McMinnville, Oregon
Does anyone have a schematic for a dino egg dispenser pcb. The game will not stop spinning
just track the wires back from the motor that's spinning to the pcb connector. the pcb can only do one of two things... 1. constant power with ground path switched on/off. or 2. constant ground with power switched on/off. If you measure the voltage going to the motor and track those wires back you should discover which it is.
I would assume it's switching the ground path on/off electronically and that component is bad. Maybe look for anything burnt looking near the connector. It could be a multi transistor array in a dip package, hard to see with the pcb angle you posted.
Appreciate it, I give that a try. I talked with s&b and there's no schematic they know of. I'll send some better pics when I get back to the game
