Dim G-07 - not tube, but on chassis?
Vectorman
McLean, Illinois
Guys,
I'm trying to figure out why I have a G-07 that has a pretty dim picture. I thought it was the tube (since this was in a cocktail). But I swapped tubes and same thing. then I swapped chassis and it got bright. So then I checked all the pots on the neck board and replaced the 3 transistors on the neck board - still dim.
So what component is weak, causing this dim picture?
Thanks in advance for your advice.
John
Screen control doesn't do it - makes the whole thing brighter, but the contrast is wrong then - everything is bright with lines through it and not usable this way.
Black level.....I don't remember seeing a black level adjustment on a G-07. Is that just another name for the Screen control?
Bad flyback? Really....can someone confirm this? If so, great...I've got a bunch of those.
Thanks guys,
John
Yes scratch the black level adjustment - sorry working on two dif monitors ;)
But I'll stay with a bad flyback.
Is that your final answer? <grin>
A possibility, but G07 flybacks tend to fail in a big cloud of smoke. In fact, most of the G07's I see have already gotten new flybacks at some point in their lives. I am still leaning towards the B+ being too low. It should be 120v.
-Ian
Are certain colors brighter than others? For example, is the red brightest, blue a bit darker, and green darkest?
If so, replace R517. Then retest....
I'd start at the blanking circuit...X303/X304 and D301. ...and then (maybe) D402/D504 and D508. Good luck, these can be tough to track down.
Edward
