trickman
I just figure out the best pattern on each level to get the most enemies to follow me so when I drop a rock, it will be at least 2500 pts (But I try to get 4000 or more per, if I can). After 2 rocks kill multiple enemies, I head for the middle to get the veggie. Once the later levels happen and multiple enemies start appearing in the starting tunnels, it's time to do what I call "tap & pump". You want to kill multiple enemies in a row that are chasing you? That's what you do. Continually tap the stick and press the pump button simultaneously when facing the enemies and do it as quickly as possible. You won't get as many points as a rock drop, but you'll stay alive and kill 'em a lot faster this way.
