antiquarius
dig dug power - can i put a new PS and bypas the ARII?
is this something thats feasible? just curious...
It is, however you would also need an Audio Amp as that is built into the ARII.
i checked voltages on the arII and was getting close to 5v, but on the main board i just checked some caps to see if anything was getting through and found usually about 3v.
Well, there's your problem
The power supply is working if you have 5v at the supply. But if you aren't getting 5v at the board, then something is wrong between the power supply and the board. It's usual to have a tenth of a volt or so drop, but two volts is an awful lot.
Inspect the board's edge connector and check for burnt marks, and look into the edge connector plug on the harness and examine for burns or corrosion.
-Ian
