FS Parts: Dig Dug PCB, G07 13" monitor, Playchoice Dual pcb, Mach 3 un-pop cp.
Nondrowsy
Edwardsville, Illinois
Only Adapter and Monitor left. All else is sold.
I had a dig dug cocktail that I was trying to piece back together that I gave up on. The G07 Monitor would only work sometimes. When it worked, decent bright picture but a few black lines on the right side, they would fade after about 10 minutes. If it didn't work no neck glow, nothing. I don't have time or patience to work on it. I did test the dig dug pcb with a mikesarcade adapter on the monitor. See pics. When the monitor would work, the pcb seemed to work just fine. Played through at least 4 levels many times. I did only run it with the adapter not through an original harness/edge connector. But, When I hooked it up to another game with a jamma harness, the game wouldn't come up correct on the screen, board still seemed to work fine.. When hooked up to the original monitor it played fine? Maybe sync issue with other monitor? Anyways...
Asking $50 picked up for the Monitor, and SOLD $85 shipped for the Dig Dug Pcb. SOLD $25 shipped for the adapter.
Also have a Playchoice 10 dual monitor pcb with tennis. I have no way to test it. I did test the PPU and CPU in my VS. system, they both work perfect. The board looks very clean and original. So the PPU and CPU are working, but assume board doesn't because I don't know. Tennis cart is untested also.
SOLDAsking $90 shipped for the PC10 Dual PCB, and $20 shipped for Tennis.SOLD
SOLDLastly a M.A.C.H. 3 unpopulated control panel in fairly nice shape. No drill holes. SOLD
Asking $40 shipped (it's heavy!)
I can get more detailed pics if requested, also will trade for Dragon's Lair parts. Thanks!
