Dokert
You have failed to meet the 2 out of 3 "Knowns" criteria. Meaning that you need 2 out of 3 of the following to be known good in order to fix your problem.
1. Power supply / Power Brick
2. Game Board / Boardset
3. Monitor
In your case you have multiple problems, which make it very difficult to assist you with as some of these problems overlap and run together.
Your only known good is currently your Power supply / Power Brick. You need a second known good in order to not end up pulling your hair out to fix the 3rd problem.
I guarantee that you have a Game Board problem. The "squeal" as you call it, is an error tone. Much easier to diagnose if you have a working monitor.
Your monitor definitely has an issue. The HOT is fine, from what I can tell. Suspect the Regulator is bad. Verify by pulling X701 and retesting the monitor with something that has a working signal. Such as your Pacman machine. This is a video game, size doesn't matter. If the monitor works with X701 pulled out, your Regulator will need to be replaced.
3. Monitor
