Oryk Zinyo
I confirmed 129VAC coming across the black wires.
That seems high, but is most likely OK.
Fuses shoud be verified with a continuity test. Do it with the power off and you should have almost no resistance across the fuse to verify it is good.Voltage across F902 is 0.000 which confirms the fuse is good.
Double checked and there is no DC voltage at either leg of R901.
This needs to be investigated. Is there voltage at F902? What about F901? Place the black lead on any chassis ground and probe with the red lead.
