armyaviation
i have a wg 19k7901. i need a new chassis. i found a 19 inch k7000 chassis that looks visually the same but the neck board has 8 pins and mine has 10 pins. can i use the new chassis and simply swap the neck boards. how do you tell if that chassis will work with my monitor.
