Difference in Pac and Ms. Pac CP Latches
Phetishboy
Avon, Minnesota
Are there any? My AS multi-game Ms. Pac CP came with no mounting latches. I am using this in a Pac cab. Will the latches from that CP swap directly? Or is there a size discrepancy because of the wood?
Well actually....
Since the Pac CP has a wood base underneath, the part that attaches to the control panel is screwed into the wood, rather than having carriage bolts that go through the top of the panel like on Ms. Pac and your new CP, so you'll need to find some carriage bolts or something similar. Make sure they're not too long, or they'll interfere with the latches.
And just measure the thickness of the wood base, and move your latches up that far...
