GO7 B+ voltage way to high, ideas?
#561480 - 10/27/07 11:48 AM Edit Reply Quote Quick Reply
Of the piles of these that i have worked on this is a first for me so any ideas would be appreciated. This thing had a very high B+ voltage before i even rebuilt it(166VDC) after a new HOT, flyback, caps, regulator etc. the voltage still is unchanged and you can twist the voltage pot all day long with no change either. This chassis got all the standard parts that i usually put in to freshen them up, but what am i missing here. The monitor won't produce a picture but the voltage is at the anode, it's just 46 volts higher than it should be.
R811--13.2 with Ohm set @ 20k
R811 -- 8.4 spare chassis
If you mean which combo is giving the " 1 " (it looks like a one to me) It is RED line to the B and the black line to the E. I did test in both directions on all the combinations.Which combination is giving you the L?
Unless the TM202 is different than the T220, this should be reading 47K ohms
