I'm editing this one to update it.
I swapped out the following as they tested odd or bad out of the board:
D804
D803
D802
R811
R809
R801 Although I have a question on this one. Its a large regtangular cermic Resister.. clearly marked 1.2K Ohm on it, same as the manual. On all 3 I have, testing in and out of the board, The meter starts off near 1 or higher but very quickly discharges down to 0, within a second or two. I haven't seen another resister behave that way.
Problem? All 3 I have (2 parts chassis) behave the same. I swapped it anyways with a part chassis one.
R813 tested ok
R807 tested ok
R802 tested ok
Transistors..
Q552
Q802 Both tested odd in board, but tested ok out of board. THOUGHT I had found the problem! But apparently not, will either swap for a parts one or get new "just in case" ***But tested good since I looked up the proper way to test transistors.***
I also swapped out the HOT for a parts one..
And I swapped Q501 ..
