kerri369
what did you use and how'd it come out?
I actually start by triple thicking the bezel.
You lost me. What does triple thicking mean?
There's a spray from Krylon called "Triple-Thick", I forget exactly which it is but it's clear, sticks well to glass, helps re-bond flaking paint and acts like a primer for touch-ups.
Here you go:
http://www.krylon.com/products/triplethick_crystal_clear_glaze
I don't get it, you're spraying the triple thick on the backside of the marquee the same side where the original paint is, then touching up on top of the triple thick??? Won't that make the new paint and the original paint appear on different levels?
Use Triple Thick(TT) with caution. Several Pinhead's have had problems with it lately. It has been theorized that the formula has changed in the last year or so. Some, including people exprienced with TT ing backglasses have had them ruined with recent TT use. Search over at RGP google group for information/experience.
awesome!!! i have alot of work to do on this pac bezel.including a corner (with yellow dots) across the entire bottom!!! take a look. whaddaya think? salvageable?
I like the artists' acrylic paint sets because they already have a lot of color choices--makes the final mixing either easy or unnecessary. They're also water-soluable which makes cleanup a lot easier and the water-base keeps them from eating into the existing inks as much.
