Did a caps kit,got no neck glow
The resistor is R103. But, if your still getting the static upon power up then its probably good. I suppose you could check it for the heck of it, its 2.7 ohms.
Hmm... The fact that it was working before you capped it tells me that you need to go back over your work. I'm sure you've already done that a million times but there has to be something there.
With the power off, remove one of the wires off of that large resistor on the side of the chassis and measure it. It should be 220 ohms from the looks of the schematics.
Matt
The resistance for R103 is 2.9 ohms
The resistance for the large resistor 181 ohms
That is fine.
That is a little low, but ya may need to remove both leads to get a proper reading.
Just trying to recap what's going on here.....
You mentioned a B+ of 159v, was that from pin 4 of the regulator or from one end of the big resistor?
What does the voltage measure on BOTH ends of the large resistor?
Is this a 19" or 25" chassis?
Were both the HOT and the Regulator properly insulated from the heatsinks?
Were capacitors C55, C56 done with the cap kit? Either of them backwards?
Definitely sounds like HV shutdown as others have mentioned. (can pull one end of D10 to verify, should fire up)
Just have to determine if it is from the power supply side of things or further down the line.
That is fine.
My B+ was measured at P202, pin 3 on the neckboard.
For the Voltage measurement on the large resistor,do you want AC or DC?
Voltage has not been measured from the large resistor,only resistance
The chassis is 19"
Both insulators are still intact and adhered to the chassis
C56 was replaced, C55 was not included in my kit,Polarity is correct on C56
Yesterday I replaced R101 6.8k 3w resistor
because if you dont know how to test b+ or dont know what a hot is, you sholdnt be touching a monitor!!
Questions for Modessit, As I said earlier I am a chassis Noob when it comes to troubleshooting. As per your steps posted above how do I perform the following?
Measure B+
Test the VR
Test the HOT
Test HV
Why is none of this posted in the K7000 troubleshooting guide sticky? Would have avoided me having to post in the first place. I appreciate everyone here trying to help thanks.
How else is he going to learn? We all have to start some where. The guy should be given props for diving into a monitor chassis even if it is feet first! LOL!
Matt
DC
Agreed...... I didn't know diddly squat about monitors and my first was a U5000 that liked to catch fire. :p
LOL! Yeah, U5000's suck. Almost as bad as BITD working on k6100's. I used to fix those things only to watch them burn up within a few minutes of being power up. This was back when the 3716's were around $15.00 and the 3792's were $10.00 or so.
Ugh...
Matt
Well that can't be right.....not if you got 159v at P202 pin 3 on the neckboard.
Give us TWO measurements, one from each end of this resistor.
I did it two ways,one test lead on the left prong one on the right and that gave me 006DCV I then put both leads simultaneously on one tab and then the other which gave me 0DCV. I don't see any other way to do it. I also noticed something else when its powered on. The resistor at R105 gets really hot.
