Demolition Man Help!
AndyD421
Marietta, Tennessee
Hello All,
I picked up a Demolition Man Pin a few days ago, and have been working it out.. one problem I have noticed is that the "launch" solenoid keeps on activating when it shouldn't be.. and it does so in 3 or 4 shot bursts. It will even throw an extra ball into play sometimes... any advice as to what could be wrong? I have the full service manual, etc, so I'm ready to work! :)
Thank you so much in advance,
Andrew
If the switches check out fine and it's doing weird stuff, I would remove the batteries with power off and let it set for a minute or 2. Then put the batteries in and try it out. You will need to re-program the game setting ( 3 or 5 ball, etc... ) Sometimes bad data gets in the ram and causes silly things to happen. Good luck.
Tried all of that, and it still didn't seem to help... I've been letting it sit in test mode to see if anything pops up, but I still haven't had any luck... :(
