Demolition Derby Schematics?
that might be a tough one, there is a 5 page pdf out there. but I think if you used a spyhunter manual, you should have much of what you would need..
I still have a cocktail in my garage, but its converted to sarge.
I have 2 paper copies of the Electrical Manual... and both appear to be print outs of the bad scan pdf :( :(
Someone must have an original to do a better scan of??
There is something that appears original on eBay below but it does not look better than the "bad scan" on ArcArc...
p
AFAIK, there is no actual cabinet wiring diagram available. The bad scan above is nothing more than an mcr3 pcb stack, of which there are are good diagrams available. Tapper and DOT are the same. The video board may be a different revision, but there are good schema available for them all. Not at my desk so i can't tell you which one goes with which revision, but they're readily available.
No one has ever seen or scanned (that i'm aware of) an actual full cabinet harness of either the 2 or 4 player Demo Derby.
