Reddogg
I've got 2 monitors that have corners that need degaussing. On one of them, the discoloration disappears when I orient the arcade East and West, but the other has discoloration regardless of orientation.
I have tried for years to fix monitors with a degaussing coil, but I can't ever get them fixed.
I have the exact same coil as seen in this video,
http://www.youtube.com/watch?v=xboO2JUvtBM&feature=player_embedded
and I follow the videos directions to a "T", along with other directions on the internet, and of course the coil does have an obvious effect on the screen, but it never fixes the issue.
I'll even do the circles so slowly that my hand will start to "burn" from the coil by the time I'm backed away far enough from the monitor.
Here's exactly what I do: I start with small circles close to and in the center of the monitor, and I SLOWLY make circles bigger and bigger as I back away from the monitor.
I've done this over and over again to the same monitor (tried 5 times in a row over about 10 minutes), but still have discolored corners.
Does anyone have any suggestions? Because I'm obviously doing something wrong if the directions for the procedure is working for EVERYONE else!
Thanks.
Thanks.
