Degaussing tool
Matt68061
Nebraska
Can anyone tell me if the pictured degaussing tool (green wand) is worth a darn OR should I stick with the black circular one? I have a finicky monitor thats needs a degauss about every 6 months...
Any advice is appreciated....just curious as the black one is double the cost and will be rarely used. But if the other one is junk....
+2 on the black circle one, I went through two other wand variants before I bought my circle one, wish I would have bought it first. And if you're saying every six months you have to degauss, then it will have it's use. The wands just don't do a good enough job, where as the circle one is usually a "one and done" method.
In a pinch, I pop the trigger on my electric drill.
Does the trick on my Pac-Man crt with small discoloration.
+1 on degaussing coil ... and use correct technique(s) when using it ... "circles ... think circles".
Thanks to all who replied. Have the black one on the way! Thanks for saving me the $$ and hassle on a potential POS!
Matt
