Degauss Wire Hookup Question - Kortek Imperial 19"
JeffC
Donor 2013
San Diego, California
Hi Folks,
Super simple question:
I just installed a new Kortek from AS and want to confirm how hooking up the degauss coil. Two wires come from the coil around the tube, one is hooked to the ground on the board, and the other is here: Does this just go to 120v AC?
The monitor is a beauty by the way, with the exception of the crazy rainbow of colors...but it's perfect if the game is in one specific orientation.
Thanks much.
Are you sure that wire you are holding is going to the degauss coil ?
That single wire looks more like the DAG wire that would normally attach to the neckboard.
Gah...this turned out to be an even dumber question that I first though...that's just a ground wire.
So everything is hooked up, I'm not sure why the monitor isn't automatically degaussing; but I haven't given the monitor manual a fair try yet.
No dumb questions around here.... as long as you found a home for that wire then it's all good.
I've seen a couple NEW monitors not degauss very well straight out of the box.
Some needed a good manual degaussing to get things straightened out.
Granted, these were Vision Pros I saw this mostly on, so not sure about the one you have.
