Deformed Objects on Asteroids Deluxe
r2084
California
Was playing someone's AD recently and noticed the the asteroids and other objects would deform slightly in certain areas of the screen. The objects seemed to get slightly narrower. It was very subtle and probably went unnoticed by the owner, I didn't mention it because I didn't know what the problem might be. I couldn't tell for sure, but it looked like the machine was all original, no cap kits or anything. Any ideas what could cause that?
The monitor has linearity pots, prob just needs an adjustment or cap kit. A lot of them aren't perfect but if its barely noticable I'm not sure its worth messing with. It would have to be put into test mode and adjusted so the lines in the cross hatch are evenly spread.
Yeah, not sure if the guy even noticed it himself. If it were mine I'd probably try to tweak it a little and see if I could get it better.
