Changing the resistor for a potentiometer just allows you to adjust the reference voltage on the LM723. On a Defender power supply the reference voltage is created by the use of a resistor voltage divider network that consist of 2 resistors. By replacing R2 with a potentiometer it allows the ratio of the two to be adjusted, thereby adjusting the reference voltage.
Over time it is possible that one or the other of the resistors has drifted causing the voltage to drop. It is also possible that the 2N6055 has aged causing the output voltage to drift as well. While I am not a big fan of just throwing a pot in to make adjustments, it will work in the short term to bring the voltage up. Once the voltage is stabalized then debugging the boards can begin.
ken
ken
