Superully
I capkitted the monitor on my defender machine and when i put everything back together again, the sound was gone
i didn't remove any wires, the only thing i DID remove was the monitor chassis - so this can't be a loose connector.
here's a picture of the sound board installed (i've read that there are different versions, so perhaps this helps):
as i've said, i don't have any sounds at all - turning the volume knob on the right (circled in red) didn't change that, BUT what i can hear when i set the volume to maximum and press the test switch (circled in yellow, at least i've read that this is a test switch, hopefully that's not a voltage regulator
) are faint sounds coming from the sound chip itself - so this seems to be working.
please check out this short video i filmed - starting at roughly four seconds in (when i turned up the volume to the max) you can hear those sounds (you have to turn up the volume on your speakers a little bit to hear it clearer).
enough said, here are my questions:
- what's the first thing you would check / do?
- could it be the speaker itself (and how do i check its function)?
note: i'm not an electro geek, so go slow on me please
