Defender - Sound Issue (cont.)
jetusenet
Donor 4 years: 2011, 2013-2014, 2024
Staten Island, New York
Hi;
This is a continuation of a "no sound" issue on my Defender:
http://forums.arcade-museum.com/showthread.php?t=164957&highlight=defender
I have already spent way too much time on this but now it is more of a quest to find the solution more than anything else!
I troubleshot the board, made the repairs, had sounds, then lost them again. I found a trace that was shorting to the mounting bracket, someone had the bright idea to just drill through the PCB and screw it to the mounting bracket! I attached a couple of pics before and after.
Anyway, the sounds come up when I boot the game, get a little garbled then vanish. There are no sounds in test. I attached a link to 2 short videos that I posted so you could hear the sounds.
http://www.youtube.com/watch?v=qGIYQanVPpk
and
http://www.youtube.com/watch?v=vvZL9LU2RLg
I have already capped the sound PCB, replaced the defective PIA and socket. Fabricated and replaced the interconnect wires. Tried replacing the 6802 for testing and had the same sound issue. All fuses are good and I even tried freeze spray of the components to see if that would bring the sounds back in test, no good.
If you could please listen to the sounds the game makes before it drops out and if it rings a bell with a similar problem you might have had, I would greatly appreciate a push in the right direction.
Thanks much
Jeff
I had a sound problem on my Robotron, turned out to be a bad PIA on the sound board (which you've already replaced). However, you can test the sound board independently (even without the test switch) by grounding the pins that receive the signals from the CPU board.
Ground each pin in sequence, you should get a different sound. At least that will tell you if the problem is local to the sound board.
If you don't get sound on all the pins, resolder the pin header -- It's a good idea anyway.
Sorry, I had so many other problems with the Defender, which I am very happy to say, the game is now working 100%, I had forgotten to post the solution to this post.....
I burned a new sound ROM and then the sound board worked!
Thanks for your suggestions and I apoligize for not closing this thread out.
Jeff
