mycldean
I have a defender also that I'm having some issues with. I was wondering if you could help me out.
When I first got it it would not power up the power on off switch on the back door was turned around backwards and screwed in to the side. The monitor cable and sound board cable were both wired diffrent then schematics showed so I have corrected that and there was some kind of power supply conversion box that I took out and fixed the original power supply.
For a while the old pcb board would spark up and blow a 4 amp fuse so I orders a new board set on line.( not eBay but from a web site)
1. I have new board set I ordered from a Web site. That is installed
2. Power supply checks out and works fine.( after a bridge rectifier replacement)
3. It looks like a fairly new vision pro monitor inside.
4.When I turn it on a hear a start up sound but no picture.*Only blue lines on horizontal scroll.
5. I get all three lit LEDs on the power supply and at start up you get ll 4 LEDs lit once and then they go off.
6. The power supply will work to run stargate as well. And the monitor from stargate when hooked into the defender board set gets scrolling blue lines
7.I have read something about the monitor not bieng ready for the original boards without a hack.
8. Iv been staring into the back of this defender for 5 days now.
Any ideas I'm going crazy here.
