after u replaced 6R again, were u getting the expected pulses ?
use logic probe and put on 6R pin 11 and tell us what you get.
if you have a multimeter with a frequency (Hz) measurement section:
- put the +ve lead onto 6R pin 11 (-ve to gnd), tell us what you get. - this is the inverted output of the main 12mhz system clock
- if your DMM overranges (ie cant display such a high clock freq.), put the probes on 6R pin 8 (and -ve the gnd) and tell us what u get. this is the 4MHz clock used by the video circuit. most DMMs should display this one.
- also check your E and Q clocks at pins 34,35 and tell us what you get. should be 1MHz. these are the system clocks that are derived from the 4MHz clock that is derived from the 12MHz main system clock.
- put the probes on 6R pin 8 (and -ve the gnd) and tell us what u get. this is the 6MHz clock also used by the video circuit. this is derieved from the 12MHz clock.
in short if 6R is not outputting clocks , the system she no work and video output wont work.
