Defender marquee light
jeh
Kansas
Ok so I've searched and found very helpful information for installing a cheap under-counter florescent light fixture. I picked one up, as well as a multimeter and some wiring supplies. However now that I'm faced with the task I'm afraid of getting shocked or blowing a fuse or something. This is my first arcade cab and I'm learning as I go.
Behind the marquee there is some existing wiring that I assume was for the original light. Can I simply test the voltage of this wiring and splice it directly to the new fixture? Or should I call someone who knows what they're doing. Thanks
On the left side of the metal plate in the pic there is or should be a plug. This is 120VAC.
You can splice directly into it or the wires feeding it. I believe they are black and black with a white stripe.
If possible salvage the plug on the old light end and repin it. Nobody likes to see the old twist and tape method.
Also, welcome
I just noticed that was your first post.
Just make sure the cab is unplugged and you'll be fine.
Just an FYI,Bob Roberts sells all the hardware to repair the original light.
It may be a bit more work but it'll keep it original. Looks like you'll need a starter, starter socket, a bulb, bulb sockets and a ballast (yours is probably bad)
in most cases it's cheaper than a new fixture.
Hey thanks a lot for your help. I'll probably try this new fixture but I'll look into originals if I can find Bob.
Ok, it's illuminated! I'm satisfied with it. Thanks gregatron.
I noticed a light leak in one corner of the marquee. Is that an arcade-museum faux pas?
If you have some scratches in the background areas, it is no big deal. If it bothers you, go to a hobby store and buy some black Testors model paint and some thinner. Thin it down a little and gently brush it on to cover the scratch.
You can do this on bezels as well. Just make sure you are patching a solid area and match the color.
ken
Fortunately this one's in pretty good shape. I'll definitely remember that for future games.
For this one I'd like to get some coin slot lights, a lock on the coin slot door, and maybe replace the control panel overlay. It has several cigarette burns and melted spots.
