Defender joystick
KidVidiot
Thread Manager
Los Angeles, California
Can someone point me to a blow up of a defender/williams two-way joystick? Mine has been giving me some problems and this is my first time messing with this kind of two way...I think I may have put it back together wrong
so no one has a blow up? basically my joystick is only going one direction with ease, whereas the other direction feels like it doesnt have enough clearance to move the metal piece to hit the switch
It's a pretty simple joystick assembly.. There are just 3 main parts and the leaves.. How about downloading a manual for either defender, joust, or moon patrol.. If neither has a blown up diagram, then your shit outa luck..
Figured the pictures of the assembly in a decent resolution was all you really needed..
The second image that Google returns is this:
What else do you need to know?
Check the centre hole where the shaft is located, its probably worn more on one side, so the shaft will move and not the actuator bar, not much you can do wrong when putting back together as they are pretty simple devices.
