dogdayaft Active member VAPS Joined May 20, 2020 Messages 140 Reaction score 34 Location mastic beach, New York Oct 22, 2025 #1 Need help with a coin door lock source Picture shows, requires a square engagement Would like a 1 1/8 inch shaft has got the standard 3/4 inch bore hole. thanks.. Attachments square hole.jpg 320.1 KB · Views: 10 defendern cocktail lock.jpg 384.3 KB · Views: 10
OP OP dogdayaft Active member VAPS Joined May 20, 2020 Messages 140 Reaction score 34 Location mastic beach, New York Oct 23, 2025 #2 I found my answer, Appears correct, thanks for looking https://www.amazon.com/Cabinet-Cylinder-Compartment-Mailbox-Thickness/dp/B0DGL4F15B/ref=sr_1_29?crid=312O5QEAGC9VA&dib=eyJ2IjoiMSJ9.a0aO9T-7sp3LPhw0fPvvei2dFNnAtV1J9IB2nlrL6VBwTYGYmQjA6Usrw8qyzeLFGGST5xf5TMrNBAOz48jd0C4fjGRxSLlQoEeM9B0_AZByjkvj4PRrjl0_BGUhTOfbAf1PIMUDgbTXl_c21ezp0NvCJFcZxyoWEQ4_077uI5V34TT9JHoog0JH5puPUJRKugilhwczx6UXL1wWlihinI_HXBAnRCRJjHRfQvuHsYJsrgekvXu4DQuDeBeP8UM3E5Cpf17So9xJtLi9TvfmGFFmVxOS9epfQg2THRWd41s.GToW4neFkweasGe7I00WwrQfglJhueu40SAqPkfTkNs&dib_tag=se&keywords=arcade%2Blocks%2Bwith%2Bkeys%2B1%2B1%2F8&qid=1761208933&sprefix=arcade%2Blocks%2Bwith%2Bkeys%2B1%2B1%2F8%2Caps%2C74&sr=8-29&th=1
