8bitnintendo
I just got my K7000 chassis back from the repair shop, and now I plug it into my MK3 cab and there is no neck glow but I hear the game playing... What can the problem be??? Bad tube???
O.k., let me get this straight.....
repaired chassis and original tube = no neck glow
repaired chassis and "known good" Simpsons tube = working monitor
repaired chassis and "known good" Neo tube = blowing fuse and eventually no picture
Are these correct?
Have you tried your repaired chassis in the Neo cab with the Neo's tube? If not, do that. And if it works in the Neo cab, you have a problem with your MK cab.
Anyone have a wiring schemadic for a dedicated MK3???
I tested the repaired chassis with one of my tubes in the Neo cab and it worked fine...
So what happens when you try this combo in the MK cab?
No power to the monitor but I can hear the game playing...
