I have a Vs Super Mario that I want to convert back to a DK. Is this pretty much a board swap?
Well, for starters, the two boards have different pinouts, VS. has horizontal monitor orientation while DK is vertical, plus the joystick for VS. is an 8-way which would make playing DK a pain in the ass...
So I would say that it would require more than just a board swap...
First you need to check if the tube is sealed tight. Grab a wrench and smack the neck, if you heard a hiss than the tube is good.
Yeah..sure..I'll get right on it. LMAOFirst you need to check if the tube is sealed tight. Grab a wrench and smack the neck, if you heard a hiss than the tube is good.
