Deconversion blues
Wolfinator
Lethbridge, Alberta, Canada
As I have been slowly turning my Relief Pitcher back into the Wizard of Wor it originally was, I have been running into all kinds of little structural modifications the operator, in his supreme cleverness, decided to make to this poor cabinet.
1. Filled in part of the t-molding channel with bondo...that was fun to carve back out!
2. Added a big ugly control panel, using not only 32 screws, but also half a can of wood glue...good times!
3. added an extra piece of wood above the marquee so the wider RP marquee would fit...this one had me scratching my head at first last night when my NOS WoW marquee was too small to fit!
4. Bolted a big piece of MDF over the entire back of the cab to fix the back door which was cracked...I have no functioning back door at the moment, but thaat is a project for the future!
5. Added and removed various pieces of wood around where the CP goes...I won't know the extent of this for sure until I get my replacement WoW CP and attempt to mount it.
6. The wiring is hacked up like crazy...I have a complete replacement harness on the way!
7. The sliding tray for the PCB is long gone!
This is what I have discovered so far anyways! I don't fault the operator for doing what he had to do to convert this badboy, in fact, it is making the job more interesting and challenging (Despite abit of swearing on my part!) I will appreciate this, my all-time favorite game, even more when it is finished because of these extra challenges!
Usually a game you want badly is worth the extra effort, and you have a lot more satisfaction knowing what you had to do to restore it.
Deconverting a game is a lot of work, and usually a lot more than you think it will be. It's amazing how undoing a change that an operator made in 5 minutes can sometimes take hours to do.
The before and after pictures are a lot more fun to look at though!
Thanx for the update; good to hear how it is going on - even how rough it may or may not be. I am considering converting mine back as well. I will need a CP, marquee, wiring harness (currently jamma), a PS, boards and a bezel... that's all.. ;) oh and side art as well.
And no lie, I have only played this game on a Multi Williams board I used to have. But the cab is screaming Wizard action at me!
Good luck with yours, can't wait to see pics!
