Deco Monitor Help
plwagner89
Washington
I just picked this up and found this broken resistor. It's not marked and I can't figure out what the chassis is. Can anyone help me with this? The bottom board is marked kb240162 if that helps any. Thanks.
I think that is what Bob calls a Kagi monitor.
I don't know where to find a manual for that one but I am sure someone else can help.
It doesn't look the same to me. The broken resistor is in R901 and I can't find that one.
Ya, it looks like it is. Thanks for your help so far. i found an old thread that mentioned a Kaga or a Nanao. I also found the number 240164 stamped on the back of the board.
My wife looked at it and has better eyes than me. On top of the resistor it says
RGB10 210 ohms K
Noble On
Can someone point me in the right direction for this one? Bob doesn't have a 210 listed.
I can't seem to find a 210 ohm. Can I use a 200 or a 220 instead? I found some on mouser but I'm not sure which one to buy.
Does anyone know if Fry's would carry anything that matches?
If it were me I'd consider using the 220 ohm as a last resort.
I have a stack of monitor chassis that I can go through and look for any resistors this size. I plan to go through the stack this afternoon/evening for someone else in WA who needs a K7500 board set. I will look for a 210 ohm 10 watt resistor while I am digging out the other stuff. I'll let you know if I find anything.
Thanks for taking a look. Any other ideas on where to look besides digikey and mouser?
Does this sound like something that will work?
210 ohm 1% 10w Wire Wound Resistor 20ppm
There's no picture with it and I'm not sure if it's the same.
