Dead DMD?
dieseldogpi
Selden, New York
Not sure if the DMD is dead and garbage or what. I tried the DMD in another game, and it didn't power on at all, nothing. Is there something specific that is causing this that could be fixed, or is it most likely the DMD is done? Thanks.
Usually at that point it is dead.
You can measure voltages at the big connector to be sure they are right. But since you tried it in another game and got the same results, you likely need a new DMD.
LTG :)
which pin did you try this DMD in? 911? I thought there was different kinds of DMD Displays for the different pinball makers?
I did try it in the Rescue 911. I was under the impression that it uses the same DMD, although the one in the R911 seems like a different color, same plugs, and looking at marco specialties, it lists the same DMD for both games.
as long as the size is right pretty sure they are all identical... have a williams dmd in a gottlieb, and a stern pin in a williams etc
