mrdion
Hi,
i am offering a way to upgrade your Dance-dance revolution board (applied to digital version only, and applied only to original konami bios boards), or some other games that used same system. the upgrade is just consist a disc image. yes, only one disc, for both installation and playing. no other thing needed.
so, for instance, you have an original DDR konami board that went bad somehow (flash rom check showed BAD, or PCCARD checksum showed BAD) and it can't be reflash by its own, because the security cart (the blue one) is broken, this one can help you.
actually, this is the real case happen to me, several times. well, several because i have some DDR cab, about five or so. it's not that i can't afford to send it in to konami japan for repair, but, fyi, i did once. i sent one bad board to them, and what i got? i paid everything just to got the board back without any repair done. and the board, is not a bootleg one, it still original one.
so, if you willing to risk to lose the chance to repair to konami, you can do upgrade/fix with these discs. and these are the list i had for the moment:
Dancing Stage EuroMIX
Dance Dance Revolution Solo 2000 905-JAA-02
Dance Dance Revolution 3rd MIX 887-JAA-02
Dance Dance Revolution 3rd MIX 887-KBA
Dance Dance Revolution 4th MIX Solo PLUS A34-JBA-02
Dance Dance Revolution 5th MIX A27-JAA-02
Dance Dance Revolution 6th MAX B19-JAA-02
Dance Freaks 874-JAA
Dance Maniax 1st MIX 874-KAA
Dance Maniax 2nd MIX A39-JAA-02
Dance Maniax 2nd Mix Append J-Paradise A38-JAA-02
DrumMania 5th MIX B05-JAA-02
Guitar Freaks 6th MIX B06-JAA-02
Percussion Freaks 4th MIX A25-KAA-02
please pm me for more information, or if you're interested.
update: If your problem is having BAD checksum(s), or PCCARD BAD, but your security cart still running, i can manage to get it fixed without make the board bootlegged.
