Daytona USA volume pot ohm rating?
srarcade80
Orlando, Florida
I picked up a twin Daytona USA cab missing the control box. Since it doesn't have the test panel, there is no volume knob and the sound is on full blast blowing out my eardrums. Does anyone know the pot rating for the volume knob so i can install a temporary one?
Actually- if anyone has a detailed schematic beyond whats found in the manual, that would be so incredibly helpful!
Yes, that's indeed a quick of Daytona...
If the connection to the Pot is broken or missing, the volume is on full blast..
(...you'd expect no wires = no sounds, but not so.... )
Steph
My ears thank you! The last page in the manual with the schematic is always hard to make out but that HTML one is actually pretty readable.
Actually- didn't quite narrow this down yet. I have a control box on the way but none of the schematics i have are the correct color codes for the wiring. I spot what I think is the correct set of wires. It a set of 3 wires running from the audio amp, exit the cab to where the control box would be and join into the main connection harness there. If I knew the pinout for these 3 wires i could build a quick volume knob.
Ryan
-EDIT
Actually i just said what the hell gave it a try, set of 3 wires on 4 pins, spaced out like 1-11, figured the far left would be ground, the other two would be signal. Put on a 10k pot and that solved the problem.
