srarcade80
I recently picked up a twin cab at a very nice price of $120. Player 2 cab works near flawless but player 1 has a strange issue. Any time the camera is on 1 of the 4 player V.R. views, its all over the place, under the track, behind scenery etc etc. If you try to play, the car just keeps turning left and right over and over. However in attract mode, any of those views are perfectly fine until it jumps to a V.R. view, then its all over the place again. Game loop seems to operate normally, all menus work fine, camera panning to the car is fine, then goes nuts after 3 2 1 Go!
So for troubleshooting, I pulled off the entire control panel and disconnected it to confirm its not one of the pots on there causing problems. No issue here.
I then ran all of the ram/rom tests in the test menu, everything checked out "Good".
Beyond that, the only thing I see is on the link board? the digital counter is flashing "08". I don't know if this is an error code or just a link ID or what not.
Any ideas?
EDIT: I was able to fix this problem, here is what you do:
On the CPU board, locate component 'PC62'. With the game powered off, use something to jump over the component like a jumper wire etc and hold it there for 20 seconds. I am not sure exactly how this fixes the problem but it worked perfectly. All 4 of my V.R. views work now.
Any ideas?
