I think I have the little board! Daughterdad on here may have the bigger one.
(Edit - in fact I'm 99% certain I do, but its at storage right now.)
That is the main board. As stated earlier, they are not cheap to replace.
You can buy cheapo toslink cables off amazon which will work fine for linking. However, there's really no reason to worry about the cables until you get another working main board.
Thanks guys, we are working on getting the parts as we speak.
Do the ROMs have to be the same on the master and the slave?
yes, they must be same.
Let me start by saying that this is not a spart method of connecting these. The light you are seeing is highly concentrated and will damage your eyes.
That being said, both units should be transmitting on one line and receiving on the other. In other words one port should be lit while the other port is not. If one of your units is not lighting a port then it is either not in link mode or something is wrong with the transmitter.
I am looking at the connector from a distance so I doubt my eyes will be damaged. It's not like I am shoving my eye directly against the port.
Both units definitely in link mode.
Games stay in test screen trying to detect network for both.
I read above that you need to connect red to black, red to black but when I bend right down to look at the outputs on both cabs, only one is showing red optical output, the other side, ie the slave side, has both outputs dark.
Is this an issue? In otherwords, only one optical out/input socket is showing the glowing red from inside the socket.
wait dok you have 3 daytons now?? bastage!!
ON those monitors, if theyre original they are probhably nanaos..
the fly adjustment knobs are just like other monitors, but instead of the knobs facing the back, they face to the side. That big metal plate is there in the way, so nanao was nice enough to drill out two holes there on the side to let you adjust.
These games are a beast... The best I could get was 3 out of six to work for various reasons... Just swapped some seats around this morning and disconnected the other two machines... I'd have thrown them out the window if they weren't so heavy. I might have some spare parts soon including boardsets and networking cables, coin box etc. Not my call in the end but I want to get rid of these ones that are causing troubles. Just wait till the camera views get screwed up and you are driving in the sky... Literally tons of fun![]()
