Daytona USA monitor connect to chassis
lbay
El Paso, Texas
I have a Daytona USA arcade (left half of a twin) that I am putting together from parts. I am finished except for connecting the monitor (Nanao MS8-26SU) to the chassis (Nanao 05T00905). The monitor has 3 connectors, one 4 wire(red,blue,yellow,brown), one 2 wire(black,white)and one 1 wire(black). Where do these connect to the chassis? Thanks for your help
the 4 wire is your yoke plug, goes to CN531(Normal), red wire closest to edge of chassis. The single black wire, if it's the one coming from the tube dag wire, it goes to CN301 of the neckboard, next to the socket. The two wire could be a couple of things, but you'd need to trace where it goes to, or supply pics of where it comes from. I'm thinking that should be your AC, but again, I'd need to see pics to confirm.
This thread has a few pics that may help:
https://forums.arcade-museum.com/showthread.php?t=393786&highlight=Ms8-26su
The 2-pin blk/wht is degauss. There is only one place on the board it'll properly connect to, near the AC input.
Hi, Thanks. Here are some pics. I really appreciate your help.
Degauss on my three monitors are all red/red, I'd still like to see some pics to be 100% sure, for his sake.
You're confusing the wires from the coil itself - which is what he is asking about - with the red wires for the remote degauss switch, which connect to the 9-position connector adjacent to where the 2-position coil connector is. The wires from the tube's degauss coil are black and white.
OP just posted pics, and these two connectors connect on the top right of the chassis in his pic - his degauss switch wires can be seen hanging on the lower left.
OP, what I mentioned with the first two connectors, is correct, and Pat is correct regarding the 3rd connector. That post sticking up at CN301(neckboard), is where the single black wire plugs to.
That's weird Pat, as on mine, I'm not confusing these wires. All of mine have two red wires to that, and two red wires to to the manual degaussing switch connector, not black and white like his above. As you stated previous, there's only one place it can connect to properly, I've just never seen black & white until this chassis/cab. It's why pics can say 1000 words :)
