Jiggy
Daytona USA DLX control problem after 10 mins of play
I recently purchased a Daytona USA Deluxe cabinet and i have a very small, but very annoying problem.
It plays like a dream, the first 10-15 minutes.
After that, something strange happens.
At first sight, nothing is wrong, but i noticed something is happening to the controls.
I can see it for example at the first track, where you have a corner you can normally take (the corner before the 'big' corner just before the start) without lifting the foot from the gas. I am able to do this flawlessly the first 10-15 minutes, after that it's impossible.
It's like the controls don't work 100% anymore, and it now gets into a drift each time i take the corner. It is not a gameplay issue but something technical.
I can also notice it in the game select screen after those 10-15 minutes, where you can make a selection for one of the 3 tracks. Normally if you have the wheel in center position, it will highlight the option you are on at that moment, but it now occasionally shifts to the one on the right, as if the steering wheel was moved to the right.
Does anyone have any idea what could be the reason for above behaviour?
I am not to familiar with the technical sides of cabinets so maybe there is something easy i could check or try after a hint from someone with experience.
Thanks in advance.
Thanks in advance.
