Daytona USA 2 screws/parts?
rcaido
Olympia, Washington
Just bought Daytona 2 cab. I was able to take most of the screws out using plyers, as i couldn't find a screw driver that i could use. Im trying to remove the side art so i can fit the monitor through the door. Is there a special screw driver that i can purchase? I went to Lowes they couldn't find one. Its like a star shape with a metal in the middle.
Also, where do you purchase spare parts? The stick shift plate, that holds the stick is broken & want it replace. Duct tape seems to working fine but yeah you know it doesn't look that nice haha.
Thanks in advance
I think you are talking about security screws. Is this what you need?
That star shape is called "TORX".
The ones with the "nipple" in the middle
are called Security Torx.
I think the size you need is T-25 and T-27.
Many auto shops carry these.
A full set should not be more than $10-15.
Cheers,
Steph
Wow you guys rock, was able to pick one up for $10 at a local auto store.
I just found out the lever that adjust the seat doesn't latch on. Looks like it broken off completely. Is there a place i can order parts for it?
