Daval pinball Odd Ball Junior 1938?
cscburford
Swindon, Wiltshire England, United Kingdom
I have just bought the above machine to restore, I am looking for a manual & wiring diagram can any body help a photo copy will do also any adverts relating to the machine (how do I post photos)
Prior to the late 70's they didn't make pinball manuals, only schematics. And I feel your chances of finding a schematic for this (old, never heard of the brand) are slim to none.
How simple are the insides? Could probably just wing it if it's simple enough.
Progress
I Have started the Restoration and trying to find things like the rubber rings looks like the modern machines use suitable ones, are the balls the same size as I need some new ones?
I have replased the incoming mains and when you plug it in the tilt light lights up is this right? Put a coin in and part of the back box lights up ( the 1000 point light is on from the start) but non of the bumpers work at the moment so it does not change could this be a common problem ? Any ideas as to where to look and non of the lights on the play field light up. Any ideas or help would be appreciated
Does it have any fuse/fuse holders? Usually that is the first place to start. A lot of EMs start in tilt but I'm talking games from the 60's and 70's so it's hard to tell if that is proper or not.
