Datsun ZZZap 280
mantadoc
Donor 2012
juelsminde, Denmark
My board is broken and i was thinking put a mame computer inside this original cabinet.
Anyone who knows how to only have this zzzap280 rom, starting directly with this game without all the games , just a emulator for zzzap280 ??? single zzzap280 emulator ?
Best regards
Richard
Denmark
Anyone who had a working board for sale ??
MAME throws up the game info screen before you play it. The only way around it is to remove the code then recompile it but you're breaking the agreement for use.
RJ
What makes you think that? Can you cite some document or portion of the license that says so?
I just downloaded the MAME source, and read the license.txt... which is quite brief for a software license. I don't see anything that would prevent one from creating and/or distributing a build that disables the subject screen.
Full license pasted here for reference:
Code:
Unless otherwise explicitly stated, all code in MAME is released under the
following license:
Copyright Nicola Salmoria and the MAME team
All rights reserved.
Redistribution and use of this code or any derivative works are permitted
provided that the following conditions are met:
* Redistributions may not be sold, nor may they be used in a commercial
product or activity.
* Redistributions that are modified from the original source must include the
complete source code, including the source code for all components used by a
binary built from the modified sources. However, as a special exception, the
source code distributed need not include anything that is normally distributed
(in either source or binary form) with the major components (compiler, kernel,
and so on) of the operating system on which the executable runs, unless that
component itself accompanies the executable.
* Redistributions must reproduce the above copyright notice, this list of
conditions and the following disclaimer in the documentation and/or other
materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
Datsun zzzap 280
I was thinking of a single rom emulator if it exist, it only have to read the zzzap roms.
Could there be problems if i do that even that i have the original board and cabinet.
Please help me :)
I sent you a PM...
Most of these games use analog sounds that are generated on the board...even if you had like an arcadesd board and could play the roms, you would have no sounds.
