Dataio Eprom Burner type of cable Help?
bluestreak
Spring, Texas
Recently purchased a Datio ChipLab Eprom burner.
Made a 24 V power supply for it and have a lead on the software that I hope will work for it.
Parallel board from Ebay on the way to put into an older PC I have.
Last part of the puzzle is the type of cable to use between the PC and burner. All of the info I have located on the internet does not say definitively what type of cable it is.
standard Parallel, Laplink, proprietary, etc.
Anyone have a Chiplab that would be willing to pass on the pinouts of the cable DB25 ends?
Not sure if all Dataio burners used the same cable or not, but willing to try any information you may have to get this thing going.
Thanks, I do know mine uses a Parallel card and not a serial card in the PC, at least according to the operators manual, so I don't think that will work, unless you are also connecting to a Parallel card.
If I can't find someone with a Data I/o unit to verify, or determine the actual one it uses, I may build a straight through and try it.
Thanks for the response.
