Gojiguy
UPDATED: 26-09-2025
Hi all,
I recently got my first candy cab and I had some trouble finding a decent autofire solution that also had remapping. Since I'm using a Taito F3 multi I wanted the ability to remap and since I have other PCBs I wanted something flexible. I wanted a Reco PCB (and eventually found one, thankfully) but it took a lot of searching since those are discontinued. So I wanted to make a thread cataloguing the available options for autofire for those interested.
Obviously, if you're using software emulation (or MiSTERcade) then this doesn't really apply, but for everyone else this should be pretty useful. I beleive most superguns have built in auto, but if yours doesnt, scope this thread! If you know any other solutions, please share them and I can update this post.
Option 1: RECO PCB - DISCONTINUED
https://rgbslab.com/en-ca/pages/reco-introduction
A great device with remapping, multiple autofire settings (30, 20, 15, 12, 10, 7.5 - synchronized or not) and the ability to map and remap all of the buttons in JAMMA. You can even wire a CPS-2 kick harness directly into it and use those buttons for PCBs that don't. So you can add multiple autofire rates to a game, for example. You can save and load multiple profiles for each player, map coin to a macro or hold, program buttons on the fly, and lock button configs for touirnaments and whatnot. All in all its pretty versatile but it doesn't go lower than 7.5hz (pour one out for Gun Frontier players), there isn't a way to modify how the autofire works (i.e. how many off vs on frames) and I dont think you can set a macro for adjusting autofire rate so your garegga setup may not be ideal. The worst part is, it is discontinued so good luck finding one anyways!
Option 2: R-03N (Rosanne) - SOLD OUT
https://booth.pm/ja/items/5670682
Duefuku's master work. This can do basically everything the Reco can (autofire, remapping) but you can also set up macros, a rapidfire adjustment button (for Garegga, for example), and you can specify the exact ON/OFF timing for rapid fire. You can even assign command input macros and it can hold up to 8 profiles.
Option 3: Autofire Device Jenny / Elena - DISCONTINUED(?)
From KVClab in Akiba, these are two autofire circuits (one appears to be sync'd to the game input, one external) that I don't know much about. Elena needs to be soldered, it looks like Jenny requires some rewiring as well. Not available on their website anymore.
Option 4: Super Rapid Fire Button Series
https://www.higenekodo.jp/h24/wiki.cgi? ... 1%BC%A5%BA
Kikuchi-kun: https://www.higenekodo.jp/shop/list.cgi ... 1602860504
Wein-kun Type-RR: https://www.higenekodo.jp/shop/list.cgi ... 1499591820
Dash: https://www.higenekodo.jp/shop/list.cgi ... 1602858715
Hey, a product thats actually in stock/ available!
Coming in three flavours, these are buttons with autofire circuits built into them. The Kikuchi-kun "rainbow" has the autofire circuit built into the button and seems like it can switch between 15 and 30hz and it displays it with a light up LED. I'm not sure HOW you change the ROF, but it says its possible. Needs to be soldered.
The Wein-kun Type-RR is more advanced and includes a button shaped rotary dial so you can daisy chain it and control the rate of fire on the fly with the dial between 8.5, 10, 12, 15, 20 and 30 shots/second. Also requires soldering.
The last is the Dash. This just wires up normally, no soldering so easy to pop in and play! The downside? Only one rate of fire and its 20hz and its not synced.
Obviously, none of these are remappers, so you'd need to split a button input out to one of these (or daisy chain it)
Option 5: Synchro Rapid Fire Board (RF-S01) / Fuu System
https://channel.beep-shop.com/products/detail/4005
another option thats actually in stock! And cheap, too. Seems to support 6 buttons. Can do 30hz, 15hz and 7.5hz. Seems like a pretty easy setup with wire crimping and some soldering. This is actually just one of many rapidfire boards that BEEP Sells and FUU makes. Obviously, no remapping here, you'd need to split a button to duplicate it, so you better love the setup!
Option 6: Crown Arcade Autofire PCB DIY kit for Sanwa OBF / Hori Hayabusa buttons
https://www.ebay.com/itm/204367969459
Requires soldering, and only 5, 10 or 15hz Autofire rates, but seems pretty simple and cheap! Also comes with a switch to choose the Autofire rates.
Option 7: Sanwa MGM-SS1 & SS2 - DISCONTINUED
viewtopic.php?t=10314
Long discontinued, but apparently a decent option. I can't find a photograph of one on the internet. Allowed up to 30hz.
Option 8: Seimitsu MG04 - DISCONTINUED
https://wiki.arcadeotaku.com/w/Seimitsu_MG04
A PCB with multiple autofire rates
Option 9: Passive Autofire (open source)
https://wiki.arcadeotaku.com/w/Passive_Autofire
A simple autofire device you can set up yourself with some basic components and some rewiring. You'll need to split cables if you want multiple buttons for the same function. There is a slight pause in fire at 30hz it seems?
Option 10: JNX Spitfire - DISCONTINUED(?)
https://www.jamma-nation-x.com/jammax/
No remapping, button A and B only, but you have nobs to adjust rate of fire. Seems long discontinued but maybe you can contact JNX and ask. In order to map multiple buttons to the same function with different rates of fire, you will need to get creative.
Option 11: Retro Electronik JAMMA Autofire V2 - DISCONTINUED
https://jammastar.com/gb/r2tronik/1846- ... meter.html
Allows you to set an autofire rate of up to 50 shots per sec(!), no remapping, simply on or off on each button so again, you'll need to split wires or daisy chain.
... and thats it for options I could find, with help from the STG Rev discord.
Hi all,
