I'm not totally sure. I've measured three different transistors, one is a 1N6057 and two are 1N6059 (a higher voltage version of the 6057). With all three I got
C-E around 0.450v
C-B around 0.595v
So in my case I'm seeing higher voltages between C-B than what you are measuring. But I'm not sure if what you are measuring could be a problem.
As for the capacitors, it is hard to say for sure unless you remove the caps and measure them. Some of your values are off, but unless you removed them and measured, you can't place a whole lot of value in those reading.
Same often applies for resistors. Sometimes you'll get a wrong reading due to other paralleled resistors in the circuit, but if you remove the resistor and measure it, it will be fine.
Edit: I'd maybe try the good PS you have in your other machine and see if it works. Before doing so, double check your fuses to make sure they are the right values.
C-E around 0.450v
C-B around 0.595v
