I'm not sure of the lockdown bar inner dimensions but the actual cabinet is 630mm wide. So maybe the lock down bar is around 635-640?
I know, I'm no help!![]()
Yeah, I was responsible for 2 of those first 21 views... was wondering this myself, as I'd looked at a Demolition Man pin recently and wondered if it'd fit down my stairway. Doesn't seem much wider than a normal pin.
Any chance I can talk one of you guys into posting the INNER (side to side) dimensions of a wide body lock down bar?
Out of curiosity, why were you inquiring about the inner dimension of that bar? Trying to reproduce one?
I'm building a VirtulPin and need to widen the cab I have. Was hoping that an actual wide body lockdown bar was going to fit but its not going to from the measurements I'm getting from people.
I see on the Virtua Pin site they sell custom size lockdown bars for $129.00
I guess the problem with the size of the lockdown bar has to do with the size of the playfield monitor you plain to use. You could make one out of 2 and cut and weld them in the middle if you don't mind a weld line in the middle.
Looks like a cool project.
Then you need to widen your criteriaI'm building a VirtulPin and need to widen the cab I have. Was hoping that an actual wide body lockdown bar was going to fit but its not going to from the measurements I'm getting from people.
Williams 1970s widebodys (Scorpion, Laser Ball to name a couple) were called superwides, inner dimensions on thier lockbar is 28 3/4 inches
I didnt say anything about using the cab. As I understood it you were looking to widen your cabinet to fit the lockbar. all you have to do to use the older lockbar is change out the front rail, and Bam!Nah, I dont like those cabs. Besides, I already have the A13 cab and its already been cut in half!!!
Thanks though!
I didnt say anything about using the cab. As I understood it you were looking to widen your cabinet to fit the lockbar. all you have to do to use the older lockbar is change out the front rail, and Bam!![]()
