Data east Batman coin door.
riarcadez
Rhode Island
Looking for a coin door with original harness or harness only for a data east Batman pinball machine. If you have one for sale, please reach out. Thanks.
I've seen a couple of your threads about this, do you not have the wiring diagram? It would be pretty easy to wire the coin door based on the colored wires from the main harness if you had that schematic in front of you. I would assume that most Data East doors should be wired the same, so most pinball coin doors of that era should be plug and play. Kind of a tall order to find a specific coin door from a parted out Batman pinball. Have you checked with any of the pinball suppliers? If I remember correctly, you can buy a lot of coin doors that are specific to the manufacturer from them. I had to do that with a re-import Williams Flintstones. As far as I remember, I just installed the door and plugged it in. (Edit: I bought mine at Pinball Life).
Before:
After:
Internal wiring:
All the pics i see online show this as a standard coin controls style coin door. Some of them have red return plastics and some have green. I have a few of these but no particular harness. The ones i have unfortunately have the DBA slot and the coin mechs shifted over to the right.
